How to rotate room labels in plan view
westvale
In defaults>floors & rooms> room labels>text style - change to custom text and check rotate with plan. For correcting without resetting all - group select (either similar items or by CTRL individually select> open transform / replicate and rotate 90° - you'll probably need to adjust location with this one. Hope that helps
Just a heads up...
I am assuming that you used the Rotate Plan View tool for the rotation.
If so, make sure that you understand the following as things may start happening that you didn't expect:
147397315_Screenshot2025-05-22at10_45_11am.thumb.jpg.3645379b28bcb4faf76f1d6de0bb2e5b.jpg
