builtright3 Posted May 12, 2025 Share Posted May 12, 2025 Good Morning! I would like to eithier find or create this Mini-Split AC Cover. I have not had much luck with doing it. Any help would be appreciated Link to comment Share on other sites More sharing options...
MarkMc Posted May 12, 2025 Share Posted May 12, 2025 Attached how to with symbol and parts in case you want to change any dimensions. Mini Split Grate.zip 1 2 Link to comment Share on other sites More sharing options...
MarkMc Posted May 12, 2025 Share Posted May 12, 2025 I just saw you are on X14. I did this in X16. Sorry about that but not doing it over. So here is the how. Start by making a molding Place a molding line using that. Transform replicate, copy that line- I did 12, think 11 is better Space at 19/11. Convert that to cabinet door, set y origin to 1/2" Place in a wall cabinet as side panel inset. Set separations to suit. Back and each side match front. Then using only 6 molding lines make a cabinet door symbol. Another wall cabinet this time 3/4" thick. Place the new door and adjust separations. Convert that to a fixture. Rotate so that it will lay parallel to the floor. Pen it up and set height plane to allow it to grow. Set first wall cabinet on the floor. Center the fixture over the cabinet in both directions and adjust height. Link to comment Share on other sites More sharing options...
builtright3 Posted May 12, 2025 Author Share Posted May 12, 2025 33 minutes ago, MarkMc said: I just saw you are on X14. I did this in X16. Sorry about that but not doing it over. So here is the how. Start by making a molding Place a molding line using that. Transform replicate, copy that line- I did 12, think 11 is better Space at 19/11. Convert that to cabinet door, set y origin to 1/2" Place in a wall cabinet as side panel inset. Set separations to suit. Back and each side match front. Then using only 6 molding lines make a cabinet door symbol. Another wall cabinet this time 3/4" thick. Place the new door and adjust separations. Convert that to a fixture. Rotate so that it will lay parallel to the floor. Pen it up and set height plane to allow it to grow. Set first wall cabinet on the floor. Center the fixture over the cabinet in both directions and adjust height. THANK YOU!!! I’m using X16, I just forgot to update my profile. Im so thank full, you saved me lots of time!!! Link to comment Share on other sites More sharing options...
