ccollin Posted May 2, 2025 Share Posted May 2, 2025 I have two decks (different heights) basically abutting each other. I've successfully added a gate where the pool stairs descend to a lower deck, but it keeps drawing an opening in the railing in the deck above. It originally did this with the stairs, but I disabled the automatic opening and it corrected the issue. Now I've drawn a gate and have the same problem. I can't see one, but I am able to select a door in the top railing and delete it, but the opening stays there. Would love to hear any suggestions. Thanks!! Link to comment Share on other sites More sharing options...
DBCooper Posted May 2, 2025 Share Posted May 2, 2025 Maybe the program thinks those railings make a "double wall"? Try setting the gate to "not through". Link to comment Share on other sites More sharing options...
Renerabbitt Posted May 2, 2025 Share Posted May 2, 2025 45 minutes ago, ccollin said: Would love to hear any suggestions build a second floor and put your upper deck up there 1 Link to comment Share on other sites More sharing options...
