capitaldesigns Posted May 1, 2025 Share Posted May 1, 2025 When I place a range from the Architectural-Appliances-Ranges-Large library I only get the outline of the range. It's missing the burners and control knobs on top. This happens for every range in the library. All of the ranges in the appliance-standard library shows correctly. Is there a setting in the Ranges-Large library that is preventing the burners and control knobs from showing up? Thanks, Mike Link to comment Share on other sites More sharing options...
Rich_Winsor Posted May 2, 2025 Share Posted May 2, 2025 I don't know about X14, but the ranges look fine in X16 to me. Link to comment Share on other sites More sharing options...
MikeJG Posted May 2, 2025 Share Posted May 2, 2025 I've run into this as well. If you open 2D Block/2D Symbol and hit 'Generate Block', it should resolve the issue in 2D. I don't remember on X14, but it will be either under 'Open Object' or 'Open Symbol'. MJG Link to comment Share on other sites More sharing options...
