ChiefuserRob2025 Posted April 29, 2025 Share Posted April 29, 2025 I am new to the product. I have a garage attached to a house. The common wall is acting strange. I can't seem to correct this issue. I have even redrawn the wall and have the same problem. How do I fix this issue? Thanks Rob Link to comment Share on other sites More sharing options...
DBCooper Posted April 29, 2025 Share Posted April 29, 2025 As far as I know, the only way to make that happen is to manually edit the wall top. The fix then is to open the wall dialog and check the box for "default wall top". If you are somehow getting a wall to do this automatically, you really need to post the plan because I have never seen the program do that. Link to comment Share on other sites More sharing options...
javatom Posted April 29, 2025 Share Posted April 29, 2025 Make sure the wall above and the foundation wall are aligned and at the exact same angle. Without seeing the plan it is hard to say but I would guess that you have a wall that is 1 or 2 degrees off from the other wall. Link to comment Share on other sites More sharing options...
