StephenM Posted April 24, 2025 Share Posted April 24, 2025 I did some adjustments to my exterior walls and now I need to adjust/move over the front entry porch a couple of inches. But for some reason now I can't remove the deck boards from the porch, its like they are stuck in the location. I've attached a picture as well as the file in compressed form. Thanks for the help! project 1.plan.zip Link to comment Share on other sites More sharing options...
SNestor Posted April 24, 2025 Share Posted April 24, 2025 Are you planning on building a deck over the rooms below in the basement? Tell us what you are attempting to construct... Link to comment Share on other sites More sharing options...
SNestor Posted April 24, 2025 Share Posted April 24, 2025 Like this? Link to comment Share on other sites More sharing options...
StephenM Posted April 24, 2025 Author Share Posted April 24, 2025 22 minutes ago, SNestor said: Are you planning on building a deck over the rooms below in the basement? Tell us what you are attempting to construct... This entry way is the current location of an as-built project I'm working on. I had to shift the exterior walls a couple inches to the left and now I'm trying to get the porch to be flush with the exterior walls but for some reason I can't get the deck boards to regenerate in the new position. Link to comment Share on other sites More sharing options...
StephenM Posted April 24, 2025 Author Share Posted April 24, 2025 When I delete my invisible wall that closes of the little entryway porch in plan view to try and get the room regenerate, I end up with this. Link to comment Share on other sites More sharing options...
PitMan71 Posted April 24, 2025 Share Posted April 24, 2025 I had no problems moving the boards. I turned the layer on in plan view and moved them. There might be more efficient way to accomplish what you are trying to do. Link to comment Share on other sites More sharing options...
PitMan71 Posted April 24, 2025 Share Posted April 24, 2025 I was able to successfully add an invisible wall at the exterior most wall edges of this porch. Then I adjusted the floor to the approximate level where you had the deck boards. Then I changed the flooring to a deck board material. I would upload the file but I can't figure out how to save to X15. Shane Link to comment Share on other sites More sharing options...
