Steve_Nyhof Posted Saturday at 12:56 PM Share Posted Saturday at 12:56 PM Does anyone have a way to create evenly spaced points between two points? But not using the Copy Multiple tool. I was even hoping a block would work and then I could stretch between the two points, but you cannot snap to the lines in the block or symbol. In AutoCAD I made up a number of Construction lines where I could very quickly get some evenly spaced lines and with a hotkey just as easily remove them. With the Copy Multiple tool it is not always easy to remove the lines from around the cabinets, lockers, etc that I use it for. It works fine, but thought there might be a more intuitive way to create temporary lines, spaces, snap points - ideas??? https://my-plan.stevenyhofdesigns.com/v/Llb9x5YzRA38LdBPznMA Thank you, Steve Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted Saturday at 01:17 PM Author Share Posted Saturday at 01:17 PM Here is one way using Point Markers because they have their own layer. You can use the Copy Multiple and then hide the markers layer. https://my-plan.stevenyhofdesigns.com/v/BiGwE0OYt2Y4GotbH0PV Link to comment Share on other sites More sharing options...
Alaskan_Son Posted Saturday at 04:38 PM Share Posted Saturday at 04:38 PM 3 hours ago, Steve_Nyhof said: Here is one way using Point Markers because they have their own layer. You can use the Copy Multiple and then hide the markers layer. https://my-plan.stevenyhofdesigns.com/v/BiGwE0OYt2Y4GotbH0PV Try using this method except instead of hiding the layer, switch back to the Point Marker tool and draw a marquee around all markers while holding the Shift key. Then simply delete them. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted Saturday at 04:52 PM Share Posted Saturday at 04:52 PM Here's another method. for you too: Draw an Arc from point A to Point B. Click Convert Curve to Polyline Set Number of Sides to your desired number of points + 1 Snap to the end points of the newly created line segments Delete polyline when you're done. 1 1 Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted Saturday at 06:49 PM Author Share Posted Saturday at 06:49 PM 2 hours ago, Alaskan_Son said: Try using this method except instead of hiding the layer, switch back to the Point Marker tool and draw a marquee around all markers while holding the Shift key. Then simply delete them. I'm very happy with this solution! Great job. The one below I understand and its great for something on a curve! Thank you! 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted yesterday at 12:10 AM Share Posted yesterday at 12:10 AM 5 hours ago, Steve_Nyhof said: The one below I understand and its great for something on a curve! Its actually useful for straight lines too. If your arc has a super large radius it essentially becomes nothing more than a straight line for all intents and purposes. 1 Link to comment Share on other sites More sharing options...
glennw Posted yesterday at 08:25 AM Share Posted yesterday at 08:25 AM Have you had a play with the Polyline Distribution Path tool? Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted yesterday at 02:53 PM Author Share Posted yesterday at 02:53 PM 6 hours ago, glennw said: Have you had a play with the Polyline Distribution Path tool? Yes, see first post Link to comment Share on other sites More sharing options...
