Ringos Posted March 24, 2025 Share Posted March 24, 2025 Using the bay window tool, I need two double hung mulled windows for the front window. Seems straight forward, but I have not found a way to place a second window next to the front window to mull them. See picture. Is the only way to accomplish that to explode the bay window and place the window and mull it? I realize I could build a bay window out of walls and place the windows, but would really like to use the bay window tool. Link to comment Share on other sites More sharing options...
glennw Posted March 25, 2025 Share Posted March 25, 2025 I think that you can only do limited editing to the windows in a Bay Window. I don't think you can add a window and mull them. To access a window for editing, select the bay by the wall that contains the window you want to edit. Hit Tab and the window will become selected for editing. Link to comment Share on other sites More sharing options...
JKEdmo Posted March 25, 2025 Share Posted March 25, 2025 4 hours ago, Ringos said: I need two double hung mulled windows for the front window. I built a mulled unit next to the bay and just copy and pasted it over (after I deleted the original center window in the bay.). See if that works for you. Link to comment Share on other sites More sharing options...
