DK7000 Posted March 10, 2025 Share Posted March 10, 2025 Is there a way to simply display, or auto-dimension, the stud lengths for a frame in an elevation view? (I'm trying to find a faster way than to do point-to-point dimension for each and every stud) Any tips or tricks would be appreciated. Thanks. Link to comment Share on other sites More sharing options...
robdyck Posted March 11, 2025 Share Posted March 11, 2025 My go-to method is a larger scale view using a framing schedule. The framing schedule only picks up items in that view and a larger scale view means the labels will be small enough that they don't obstruct the view. I use 1/2" scale for wall details with a text size of 2". This allows me to use the least amount of dimension lines as are appropriate for the wall. In the wall detail view, select the faming schedule tool and drop it into view. Then, adjust the columns to suit your needs. Keep in mind that providing full component dimensions is only practical information for: ordering material framers who understand and can achieve perfection...this means the rest of your plan has to be accurate...no 4" or 6" walls or incorrect dimensions for tub walls, stairwells and so on. 2 Link to comment Share on other sites More sharing options...
para-CAD Posted March 13, 2025 Share Posted March 13, 2025 Rob, I like how clean you make it. My way is a bit overwhelming but since I'm the guy cutting the members.....I manage. This is all 2D...not linked to the model. Link to comment Share on other sites More sharing options...
robdyck Posted March 13, 2025 Share Posted March 13, 2025 @para-CADThanks. That example was not an actual drawing yet so it's too clean! I don't draw those the same for everyone. I only provide the schedule for those who want it, and other wise I generally provide critical dimensions. I've only had a few carpenters who ask for or appreciate all those dimensions and then I'll provide whatever they feel will help them. 1 Link to comment Share on other sites More sharing options...
