Ange822 Posted March 4, 2025 Share Posted March 4, 2025 Hi there - I am wondering if there is a way to place a faucet into a base cabinet and have it "snap" or move with the cabinet when it's moved. (Similar to when a sink is inserted). I played around with the "options" tab within the fixture but nothing has made it "snap" to the cabinet. Since I started using chief I have just been selecting the cabinet + the faucet and moving it together, but I just wondered if there was an easier way as I would like to share some vanities with some colleagues. Thanks in advanced! Link to comment Share on other sites More sharing options...
Kbird1 Posted March 4, 2025 Share Posted March 4, 2025 You should be able to block them together (architectural block) , you can also turn it into a symbol if it's a combo you use regularly and add it to you user Library, the A.Block can also be added to your User Library too actually with the advantage of the faucet remaining changable if needed. M. Link to comment Share on other sites More sharing options...
Ange822 Posted March 4, 2025 Author Share Posted March 4, 2025 1 minute ago, Kbird1 said: You should be able to block them together (architectural block) , you can also turn it into a symbol if it's a combo you use regularly and add it to you user Library, the A.Block can also be added to your User Library too actually with the advantage of the faucet remaining changable if needed. M. Okay great thanks! I have blocked them before but wondered if there was another way Link to comment Share on other sites More sharing options...
