decorators3 Posted yesterday at 11:58 AM Share Posted yesterday at 11:58 AM Hi is there a video on creating outside stairs to side basement entrance. ( full basement but terrain cuts lower portion of house) I must be having a brain freeze because I've done it before but am drawing it complete blank Cheers Link to comment Share on other sites More sharing options...
robdyck Posted yesterday at 02:32 PM Share Posted yesterday at 02:32 PM Usually you will need to use foundation wall on the foundation level to create a room for the stairs. If the terrain is on Floor 1, this will NOT create a hole in the terrain. You can either create the hole manually using a polyline or terrain feature (recommended) OR create a room of invisible walls on Floor 1 (I do not recommend this). The stairs can be drawn on the foundation level, however you will need to set the heights manually. Link to comment Share on other sites More sharing options...
decorators3 Posted 22 hours ago Author Share Posted 22 hours ago 5 hours ago, robdyck said: Usually you will need to use foundation wall on the foundation level to create a room for the stairs. If the terrain is on Floor 1, this will NOT create a hole in the terrain. You can either create the hole manually using a polyline or terrain feature (recommended) OR create a room of invisible walls on Floor 1 (I do not recommend this). The stairs can be drawn on the foundation level, however you will need to set the heights manually. ok thanks got it Link to comment Share on other sites More sharing options...
