raltd9245 Posted February 20, 2025 Share Posted February 20, 2025 stair symbol or how to? Never saw your answer Please refile Thanks Ron Ravenscroft Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 20, 2025 Share Posted February 20, 2025 Hi Ron, Spiral Stairs have very specific requirements which the current Stair Tool can't address: Max Riser height = 9.5" Min Tread depth at walk line = 6.5" Min Tread width 26" inside Handrail Generally the above will mean a minimum Tread angle of 30 degrees. The number of treads will be determined by the floor-floor height which means the total included angle may be more than 360 degrees. To get all of this Chief would need to have a completely separate tool for Spiral Stairs which would need to specify the above plus: Inside Radius (pole diameter/radius) Outside Radius Bottom Elevation Top Elevation It's not realistic for Chief to just provide a stair symbol since there are too many variations. Several years ago I created a set of 3D symbols (components) to make up any required Spiral Stair. These included: Treads (with and without risers) Poles Handrails (a variety of styles) Landings If you have a specific situation you need I can make the symbol for you - $100 each symbol. 1 1 Link to comment Share on other sites More sharing options...
raltd9245 Posted February 20, 2025 Author Share Posted February 20, 2025 Thanks Joe, Much appreciated Regards Ron Ravenscroft Link to comment Share on other sites More sharing options...
raltd9245 Posted February 20, 2025 Author Share Posted February 20, 2025 5 hours ago, Joe_Carrick said: Hi Ron, Spiral Stairs have very specific requirements which the current Stair Tool can't address: Max Riser height = 9.5" Min Tread depth at walk line = 6.5" Min Tread width 26" inside Handrail Generally the above will mean a minimum Tread angle of 30 degrees. The number of treads will be determined by the floor-floor height which means the total included angle may be more than 360 degrees. To get all of this Chief would need to have a completely separate tool for Spiral Stairs which would need to specify the above plus: Inside Radius (pole diameter/radius) Outside Radius Bottom Elevation Top Elevation It's not realistic for Chief to just provide a stair symbol since there are too many variations. Several years ago I created a set of 3D symbols (components) to make up any required Spiral Stair. These included: Treads (with and without risers) Poles Handrails (a variety of styles) Landings If you have a specific situation you need I can make the symbol for you - $100 each symbol. It would a great service to users if they did spend the time and energy to give us a useful spiral stair tool. Just my opinion!!!! Link to comment Share on other sites More sharing options...
