ROBLJR
ROBLJR
Hi, I have tried every setting I can to allow me to move an extension line from one side of an interior wall main layer to the other. It always snaps to the wall surface on the opposite side of the wall, which throws out the dimensions for the framer. What am I missing?
One possibility is to check the Dimension Defaults for the Default Set you are using:
1104007440_ScreenShot02-07-25at08_51AM.thumb.JPG.dfb6f898250a6857bb91554c8b2d68d1.JPG
Another possible solution is to select the Extension - not the horizontal dimension line - and adjust it's length by moving the highlighted grip handle:
1152880940_ScreenShot02-07-25at08_54AM.thumb.JPG.f100cb9258683acbaac10388a86613d4.JPG
I have the settings set to locate interior and exterior to primary and secondary sides, in both the the default set in use and in the Overall dimension defaults. I tried changing the length of the
extension line, but it still only snaps to the surface. It's a head scratcher.
