DeLayDesign Posted February 7, 2025 Share Posted February 7, 2025 I'm not entirely sure what's happening. Normally when I use Chief I max out my lighting to like 8000 just to be sure all the lights are on; but for my recent basement plan turning on more than 20 - causes them all to go off. Does anyone have any incite into why this is happening? Link to comment Share on other sites More sharing options...
scottharris Posted February 7, 2025 Share Posted February 7, 2025 Adam, does a light set work by using specific lights by room? Link to comment Share on other sites More sharing options...
DeLayDesign Posted February 7, 2025 Author Share Posted February 7, 2025 I though it had something to do with my furred walls around the perimeter. Whenever I would turn one particular wall to a 'furred wall' I could turn on at least 8 lights with the camera that wouldn't allow any... however - through process of elimination - I discovered an object I imported into Chief from the 3Dwarehouse (a treadmill) was the culprit. I'm not entirely sure why. I sent it off to the support team for clarity... but removing the treadmill fixed the issue. Strangely though, I opened the same treadmill fil in Sketchup. Saved it down to an earlier version (2016) and reimported it into Chief and it isn't causing any issues. Link to comment Share on other sites More sharing options...
