Display Line Weight
JKEdmo
Go to solution Solved by DBCooper,
Good morning,
For one of my projects the display line weights have "suddenly" become very fat:
As opposed to this below -- another project -- which looks normal to me:
Both are PLAN files with Line Weights turned on.  This happened "suddenly", so I feel like I may have changed some obscure line weight setting that affected the problem PLAN file only (not global).
Any thoughts?
Thanks again,
Jim
  • Solution
Go to your drawing sheet setup and make sure plans have the same sheet size, drawing scale and line weight options.  If it's not one of those settings it could be the layer set.
Thank you sir.  Drawing Sheet Setup it was.  D'oh!
I had accidentally change my drawing scale to something weird.  Changed it back and that fixed it.
Jim
