rwdozier Posted January 31, 2025 Share Posted January 31, 2025 X11, anyone have a solution for this? c:\p4sync\dev\releases\21\chief\source\layoutview.cpp(657): Warning #272032582 "One or more of the views on the layout could not be updated because the original saved camera could not be found." 1/30/2025 11:13:50 PM Build: 21.3.1.1x64 Link to comment Share on other sites More sharing options...
DBCooper Posted January 31, 2025 Share Posted January 31, 2025 Maybe you accidently deleted that camera at some point? Regardless, if the camera is missing then you can't update the view. You should probably find the layout box with the missing view, recreate the camera and view, and then either relink the box to the new camera or just resend it. Link to comment Share on other sites More sharing options...
rwdozier Posted January 31, 2025 Author Share Posted January 31, 2025 Thanks for your reply! I had deleted some elevations on layout page 8, deleted the cross sections and recreated the elevations I had on page 8. Little did I know that the original elevations on page 8 also had a copy of them on a "scratch" page 19, therefore the update error. I deleted the elevations on page 19 and problem solved! Link to comment Share on other sites More sharing options...
