JKreider Posted January 29 Share Posted January 29 I am using the molding polyline tool to model HVAC ducting and plumbing. How can I create a T intersection in a polyline? Link to comment Share on other sites More sharing options...
basketballman Posted January 29 Share Posted January 29 Do an L, then copy & reflect about ... Link to comment Share on other sites More sharing options...
basketballman Posted January 29 Share Posted January 29 Or a half T, then copy & reflect about .. Link to comment Share on other sites More sharing options...
JKreider Posted January 29 Author Share Posted January 29 To clarify, can a polyline as a single unit exist in a T shape? See attached T-shaped polyline. Basketballman, your idea is a workaround, not an answer.Polyline.plan Link to comment Share on other sites More sharing options...
robdyck Posted January 29 Share Posted January 29 On 1/29/2025 at 8:16 PM, JKreider said: How can I create a T intersection in a polyline Expand You can drawn a L shape, then disconnect the new line in order to extend it in the opposite direction. A T will not work. Bad Example: T drawn by drawing the molding L line back on itself and extending beyond the perpendicular segment: Instead: Link to comment Share on other sites More sharing options...
JKreider Posted January 30 Author Share Posted January 30 Robert, what is the name of the icon/tool your red arrow points to? I do not see that anywhere on my toolbars. Link to comment Share on other sites More sharing options...
robdyck Posted January 30 Share Posted January 30 Disconnect Selected Edge. This tool shows up at the bottom when you single click on a polyline (needs more than one segment). I'll get a notification if you use the @JKreider format! Link to comment Share on other sites More sharing options...
