JKreider Posted yesterday at 08:16 PM Share Posted yesterday at 08:16 PM I am using the molding polyline tool to model HVAC ducting and plumbing. How can I create a T intersection in a polyline? Link to comment Share on other sites More sharing options...
basketballman Posted yesterday at 08:25 PM Share Posted yesterday at 08:25 PM Do an L, then copy & reflect about ... Link to comment Share on other sites More sharing options...
basketballman Posted yesterday at 08:26 PM Share Posted yesterday at 08:26 PM Or a half T, then copy & reflect about .. Link to comment Share on other sites More sharing options...
JKreider Posted yesterday at 10:38 PM Author Share Posted yesterday at 10:38 PM To clarify, can a polyline as a single unit exist in a T shape? See attached T-shaped polyline. Basketballman, your idea is a workaround, not an answer.Polyline.plan Link to comment Share on other sites More sharing options...
robdyck Posted yesterday at 11:21 PM Share Posted yesterday at 11:21 PM 2 hours ago, JKreider said: How can I create a T intersection in a polyline You can drawn a L shape, then disconnect the new line in order to extend it in the opposite direction. A T will not work. Bad Example: T drawn by drawing the molding L line back on itself and extending beyond the perpendicular segment: Instead: Link to comment Share on other sites More sharing options...
JKreider Posted 23 hours ago Author Share Posted 23 hours ago Robert, what is the name of the icon/tool your red arrow points to? I do not see that anywhere on my toolbars. Link to comment Share on other sites More sharing options...
robdyck Posted 23 hours ago Share Posted 23 hours ago Disconnect Selected Edge. This tool shows up at the bottom when you single click on a polyline (needs more than one segment). I'll get a notification if you use the @JKreider format! Link to comment Share on other sites More sharing options...
