447Debbie Posted January 27, 2025 Share Posted January 27, 2025 I cannot figure this out. I have spent in excess of 8 hours on this, referenced the manual, watched videos, still nothing. I would think it would be simple to just adjust the three elevations and it would all work, but it does not. Just one example, the area 3' from the garage front is supposed to dip 3", but instead it raises up. I really don't know how I got this first rendition but I think it was pure luck. It seems the program gets confused when your slope changes direction. The three items in the green boxes are what I'm trying to change. I want to change the garage elevation from 1964.33' to 1967.328' I want the 3" dip to go from 1964.08' to 1967.078' I want the point 23' from the garage to go from 1966.08' to 1969.078'. I want everything else to remain the same, with the exception of the slope which will change accordingly, if all works. What tools do I need to do this since going in and changing the elevation lines is not working? Home Designer Pro 2021. Untitled 1.zip Link to comment Share on other sites More sharing options...
Renerabbitt Posted January 27, 2025 Share Posted January 27, 2025 3 hours ago, 447Debbie said: The three items in the green boxes are what I'm trying to change. I want to change the garage elevation from 1964.33' to 1967.328' I want the 3" dip to go from 1964.08' to 1967.078' I want the point 23' from the garage to go from 1966.08' to 1969.078'. I want everything else to remain the same, with the exception of the slope which will change accordingly, if all works. What tools do I need to do this since going in and changing the elevation lines is not working? Get rid of all the other data and let chief interpolate. youre going to be grading anyways, just get all of it out of there and stick to the data you need. Remove the terrain retaining walls , they cause an automatic step. Put a terrain break in for your 3" drop with data on either side 3 hours ago, 447Debbie said: Home Designer Pro 2021. This forum is for the Premiere line, Hometalk is for the home designer line where people will know how to better instruct you Link to comment Share on other sites More sharing options...
Mark3D Posted January 28, 2025 Share Posted January 28, 2025 There is 2 elevation lines that cross the retaining walls near garage entry pull back to the other side of retaining wall that should look better, also turn terrain surface smoothing to low that will hopefully give you a bit more control Link to comment Share on other sites More sharing options...
