Vicki17 Posted Friday at 05:35 PM Share Posted Friday at 05:35 PM I am searching for what the setting issue is because my floor plan shows a wall at 141" and the elevation shows the same wall at 140 1/2" . The 140 1/2" is correct and the floor plan dimension looks like it is pulling from further in the wall but I can't figure out how to change this. Any suggestions? Link to comment Share on other sites More sharing options...
SHCanada2 Posted Friday at 07:10 PM Share Posted Friday at 07:10 PM the dimensions can go to the framing or to wall surfaces. My guess is one goes to 1/2" drywall and the other does not. You could post the plan for more definitive results Link to comment Share on other sites More sharing options...
Vicki17 Posted Friday at 07:23 PM Author Share Posted Friday at 07:23 PM Yes that sounds just right. Do you know where I find the setting for plans vs elevations for this? Link to comment Share on other sites More sharing options...
SHCanada2 Posted Friday at 08:04 PM Share Posted Friday at 08:04 PM dimension defaults. You can also use point 2 point dimension and just pick where it dimensions to as you move the mouse along, at least for the plan view. Link to comment Share on other sites More sharing options...
Renerabbitt Posted Friday at 09:18 PM Share Posted Friday at 09:18 PM 1 hour ago, Vicki17 said: Yes that sounds just right. Do you know where I find the setting for plans vs elevations for this? Hit the Edit The Active View Button for your current elevation and change the dimension default. for defaults go to Edit/Default Settings/Camera Tools/Cross Section/Elevation and change your default for dimensions Link to comment Share on other sites More sharing options...
Vicki17 Posted Monday at 03:45 PM Author Share Posted Monday at 03:45 PM Thanks is this something that would ever be an issue if I purchased your template @Renerabbitt When I open plan default settings how do I know if I want the living area to go to "Main Layer" or "Surface" RIght now it says main layer. I sort of feel like I am reading a foreign language so if you think that purchasing your template would eliminate these issues pls let me know. I see default settings but dont see exactly what you are referring to. Link to comment Share on other sites More sharing options...
SHCanada2 Posted Monday at 04:18 PM Share Posted Monday at 04:18 PM 25 minutes ago, Vicki17 said: When I open plan default settings how do I know if I want the living area to go to "Main Layer" or "Surface" "surface" is typically drywall to drywall, where "main layer" is typically stud to stud. As to which one to use, that would typically depend on what your client expects. Link to comment Share on other sites More sharing options...
