Michael_C Posted January 11, 2025 Share Posted January 11, 2025 Good morning, I'm having trouble finding video's or talk on foundation dimensions for adding both foundation wall and outside brick layer overall dimensions. I don't need the overall brick dimensions but its ok to be there. I would like to make a default for the foundation layer to just show outside foundation wall dimension. Builders here often use the footing for the brick ledge this is why I need to change the default. Thanks for the help! Michael Link to comment Share on other sites More sharing options...
SHCanada2 Posted January 12, 2025 Share Posted January 12, 2025 not sure what you are looking for, dimension to the outside of the foundation wall, or to the outside of the footing, or both? A diagram or marked up plan might help Link to comment Share on other sites More sharing options...
DeLayDesign Posted January 14, 2025 Share Posted January 14, 2025 Under the wall properties you can tell chief what you want your auto dimensions to dimension to. If your wall has multiple layers, you can click the drop down to choose what layer you want the dimension to 1 Link to comment Share on other sites More sharing options...
