Send to Layout Form
Condor0811
If you need to have both 1/4 and 1/2 scales available for the elevations, I change the scale when sending to layout (your capture above) and check Use Layout Line Scaling.  You can do it after the fact in the layout by selecting the view port, go to the pop up edit menu and pick the little scale.  A dialog will open to change the scale.
