Angled Stairs
bdammeyer
Go to solution Solved by DBCooper,
Can anybody tell me how to make a staircase that starts out straight and then widens at the bottom? See attached picture. The flared stairs tool gets me close but I need the flared sections to be straight lines (not curves).  Found a few people on this forum asking about this but couldn't find any solutions.
Thanks
x15
windows 11 Pro
Nvidia RTX 3080 Ti Laptop GPU
  • Solution
I think you can do this with "winders".  Draw the outline you want with room divider walls and turning on winders should make it work.
If that doesn't work out for you, you could also create each step using a landing.
