bdammeyer Posted December 12 Share Posted December 12 Can anybody tell me how to make a staircase that starts out straight and then widens at the bottom? See attached picture. The flared stairs tool gets me close but I need the flared sections to be straight lines (not curves). Found a few people on this forum asking about this but couldn't find any solutions. Thanks x15 windows 11 Pro Nvidia RTX 3080 Ti Laptop GPU Link to comment Share on other sites More sharing options...
Solution DBCooper Posted December 12 Solution Share Posted December 12 I think you can do this with "winders". Draw the outline you want with room divider walls and turning on winders should make it work. If that doesn't work out for you, you could also create each step using a landing. Link to comment Share on other sites More sharing options...
bdammeyer Posted December 12 Author Share Posted December 12 Thank you DBCooper - You tha man. Link to comment Share on other sites More sharing options...
