Jock1959 Posted December 12, 2024 Share Posted December 12, 2024 CA question Transparency.pdfsee the solid fill is " NOT solid" the room names and dimensions show through how can this be made solid.CA question Transparency.pdf The transparency is set to Zero CA question Transparency.pdf Link to comment Share on other sites More sharing options...
ericepv Posted December 12, 2024 Share Posted December 12, 2024 30 minutes ago, Jock1959 said: CA question Transparency.pdfsee the solid fill is " NOT solid" the room names and dimensions show through how can this be made solid.CA question Transparency.pdf The transparency is set to Zero CA question Transparency.pdf 205.24 kB · 2 downloads In the DBX for your polyline, go to the 'Fill Style' tab and for the Pattern, select 'Solid'. Then, in 'Pattern Appearance', select the color of your choice. Link to comment Share on other sites More sharing options...
Solution JKEdmo Posted December 12, 2024 Solution Share Posted December 12, 2024 1 hour ago, Jock1959 said: the room names and dimensions show through Might be an object Draw Order issue. Select the object and change the draw order to bring it forward, i.e. in front of the other objects. Jim 1 Link to comment Share on other sites More sharing options...
Jock1959 Posted December 12, 2024 Author Share Posted December 12, 2024 that was it, a new function for me Thank you Link to comment Share on other sites More sharing options...
