rcmcdougle Posted November 23, 2024 Share Posted November 23, 2024 How do I set my defaults for a PBR render in record Walkthrough? Every time I click the record walkthrough button I must toggle through a few screens to get the render settings I want. Every time I select PBR, the dialog shows 1000 samples and the Cap option is not checked. I want 50 samples with Cap option. Ideally, PBR would be my default for Walkthrough render mode going forward. Is there a way to set this in X15? Link to comment Share on other sites More sharing options...
Rich_Winsor Posted November 24, 2024 Share Posted November 24, 2024 17 hours ago, rcmcdougle said: I want 50 samples with Cap option. Ideally, PBR would be my default for Walkthrough render mode going forward. Is there a way to set this in X15? You need to change two default settings. I think the process is basically the same in X15 but here is how to set the defaults in X16. Link to comment Share on other sites More sharing options...
rcmcdougle Posted November 29, 2024 Author Share Posted November 29, 2024 On 11/24/2024 at 1:11 AM, Rich_Winsor said: You need to change two default settings. I think the process is basically the same in X15 but here is how to set the defaults in X16. I have done this, both in the current plan and in a new plan to save as template. These settings do not stick and I must (most of the time as my preferences sometimes linger) click through all the screens each time I render a walkthrough. I even need to double check the resolution each time as that seems to change at random intervals. It would seem we need to save that info on a per walkthrough basis just like saving a camera. It is really annoying to go through this selection process every time as I tweak lighting and/or camera angle on a 4 or 5 node walkthrough. Link to comment Share on other sites More sharing options...
Renerabbitt Posted November 30, 2024 Share Posted November 30, 2024 I go over some more details on this in the video above at 7:23 Link to comment Share on other sites More sharing options...
