AMDInteriors Posted November 9, 2024 Share Posted November 9, 2024 I'm trying to display floor hatch/fill style on a floor covering plan. It will avoid tall cabinets but is visible under base cabinets. How can I fix this? Thanks Link to comment Share on other sites More sharing options...
DBCooper Posted November 10, 2024 Share Posted November 10, 2024 Post a picture of the problem you are seeing. Link to comment Share on other sites More sharing options...
Hammer7 Posted November 10, 2024 Share Posted November 10, 2024 Use the display order icon at the bottom toolbar, a black and white page icon. Link to comment Share on other sites More sharing options...
AMDInteriors Posted November 10, 2024 Author Share Posted November 10, 2024 Tile hatch appears under the base cabinet but not the tall one. I have already tried to force the display order and that didn't work. Link to comment Share on other sites More sharing options...
Hammer7 Posted November 10, 2024 Share Posted November 10, 2024 On the tall cabinet check the fill and the transparency percentage and compare it to the vanity specs. Link to comment Share on other sites More sharing options...
DBCooper Posted November 10, 2024 Share Posted November 10, 2024 I am guessing that you set the floor pattern in the room dialog. The base cabinet probably has its fill style set to have transparency which is why you can see the floor pattern underneath it. You should be able to get what you want by making the fill style fully opaque. In the future, I recommend a larger picture. The one above is pretty small. Link to comment Share on other sites More sharing options...
