sthieldesign Posted 13 hours ago Share Posted 13 hours ago I have changed the flooring but the hatching is still showing previous material hatch. The material dropper has the correct material and hatch. There is no fill hatch on the room. Not sure what is going on? Link to comment Share on other sites More sharing options...
DBCooper Posted 12 hours ago Share Posted 12 hours ago The room's floor material will only display in a camera view. The room's fill style will only display in floor plan views. Changing one will not change the other because they are completely independent. You will have to set your fill style for your room to something that matches your material. Link to comment Share on other sites More sharing options...
sthieldesign Posted 12 hours ago Author Share Posted 12 hours ago Thank you! I am not sure how I got the large hatch to show on floor plan view without a fill. Link to comment Share on other sites More sharing options...
DBCooper Posted 11 hours ago Share Posted 11 hours ago Maybe you used a polyline or some other object? If you can't figure it out, then you could post the plan and someone else probably could. Link to comment Share on other sites More sharing options...
