FLOOR HATCHING NOT SYNCING
sthieldesign
I have changed the flooring but the hatching is still showing previous material hatch.
The material dropper has the correct material and hatch.
There is no fill hatch on the room.
Not sure what is going on?
The room's floor material will only display in a camera view.  The room's fill style will only display in floor plan views.  Changing one will not change the other because they are completely independent.  You will have to set your fill style for your room to something that matches your material.
Click in one of your rooms with the floor pattern.  You should have the room selected (look in the status bar).  Hit tab or click "next".  You should have a standard polyline selected.  Open the dialog.  It has a 36x36 grid set as the fill style.
