sthieldesign Posted November 7, 2024 Share Posted November 7, 2024 I have changed the flooring but the hatching is still showing previous material hatch. The material dropper has the correct material and hatch. There is no fill hatch on the room. Not sure what is going on? Link to comment Share on other sites More sharing options...
DBCooper Posted November 8, 2024 Share Posted November 8, 2024 The room's floor material will only display in a camera view. The room's fill style will only display in floor plan views. Changing one will not change the other because they are completely independent. You will have to set your fill style for your room to something that matches your material. Link to comment Share on other sites More sharing options...
sthieldesign Posted November 8, 2024 Author Share Posted November 8, 2024 Thank you! I am not sure how I got the large hatch to show on floor plan view without a fill. Link to comment Share on other sites More sharing options...
DBCooper Posted November 8, 2024 Share Posted November 8, 2024 Maybe you used a polyline or some other object? If you can't figure it out, then you could post the plan and someone else probably could. Link to comment Share on other sites More sharing options...
sthieldesign Posted November 8, 2024 Author Share Posted November 8, 2024 Thank you, I worked on this file a couple years ago and we need to make some changes. https://www.dropbox.com/scl/fi/nkgzpj1ut9j1ia7mmrun8/WILLIAMS-BACKUP-11.8.24.zip?rlkey=2p2gvtgxflcdcxvqsvuvkwnz3&dl=0 Link to comment Share on other sites More sharing options...
DBCooper Posted November 8, 2024 Share Posted November 8, 2024 Click in one of your rooms with the floor pattern. You should have the room selected (look in the status bar). Hit tab or click "next". You should have a standard polyline selected. Open the dialog. It has a 36x36 grid set as the fill style. Link to comment Share on other sites More sharing options...
