kathleenjennison Posted October 22 Share Posted October 22 I just updated to the latest version within x16 and the make CAD block tool is missing from my edit toolbar. I searched in the customize toolbar for the tool and it's not coming up. Anyone know where I can find the make CAD block tool? Link to comment Share on other sites More sharing options...
Renerabbitt Posted October 22 Share Posted October 22 31 minutes ago, kathleenjennison said: I just updated to the latest version within x16 and the make CAD block tool is missing from my edit toolbar. I searched in the customize toolbar for the tool and it's not coming up. Anyone know where I can find the make CAD block tool? it's still there, you would either need to select multiple cad elements or shift click one cad element for it to appear in your edit toolbar Link to comment Share on other sites More sharing options...
DBCooper Posted October 23 Share Posted October 23 Try this, draw 2 cad lines and select them both. If you don't see the "make cad block" tool, then there is something wrong. Maybe you are not actually using Chief Architect Premier? If you are, then you might want to post your plan or call tech support. If you get the make cad block tool for 2 lines but not for some other group of objects, then you probably selected something that can't go into a cad block. Most architectural objects, like cabinets and walls can't go into a cad block. Link to comment Share on other sites More sharing options...
