Can a roof label be changed in 'defaults'?
ValleyGuy
Go to solution Solved by DBCooper,
  • Solution
I don't know of a way to set the default for roof labels to use a macro.  If you want an easy way to change them all at once, you can use the "edit all roof planes" tool.  And, to get rid of the white background used for the label, you just need to change the text style that is being used.  Check the box for "transparent (not used when fill style available)".
Thanks DB, this will get me to where I want it to be. Thanks for the tip on Transparent, I hadn't learned that yet.
