Ange822 Posted October 21, 2024 Share Posted October 21, 2024 Good morning, I wondered if there was an easy way to do this sort of brick detail below the bay window shown in the attached image? I was going to manually draw 3D solids / copy and paste in the pattern but wondered if there might be another way. I don't do too many house with all brick / bay windows, so anything is helpful! Thanks in advanced! Link to comment Share on other sites More sharing options...
Gawdzira Posted October 21, 2024 Share Posted October 21, 2024 There is no easy way to achieve that if you want the actual bricks modeled. If you make a solid cone and slice it to the approximate shape, you could apply a texture with a bump map to get the general look. Link to comment Share on other sites More sharing options...
