woodwizard Posted October 13, 2024 Share Posted October 13, 2024 I am trying to correct a drawing that the side wall material (Brick) shows on the front wall elevation (stone). I know that this is something simple but ca not figure it out. Any advice appreciated. Anthony Link to comment Share on other sites More sharing options...
DBCooper Posted October 13, 2024 Share Posted October 13, 2024 Did you use the material painter? If so, then don't. The material painter just changes the surface material on a wall and usually isn't what you want to do. If you mistakenly change the wall surface material for the "exterior room" it will override everything else. One way to fix these kind of problems is to repaint the walls with "use default" for the material. The best way to have one wall with one material and another wall with something else is to use two different "wall types". Setup one wall type as brick and the other as stone and use them for the different walls. Here is a pretty basic video that may help: https://www.chiefarchitect.com/videos/watch/5/drawing-walls.html If you need a more specific answers, then you probably need to post a plan (or at least some pictures) along with more specific questions. Link to comment Share on other sites More sharing options...
