Import Pdf
pazzfam
Have seen this before. The visibility of lines varied as I zoomed in and out. As I was just playing around I did not pursue it any further. Try printing the plan to see if the lines are really there. Also, when the pdf file was created the resolution may have been set really low to keep the file size down. My pdf converter allows this to be set from 72 dp up to 1,200 or higher for print level production publishing.
Graham
