decorators3 Posted October 1, 2024 Share Posted October 1, 2024 How do I get this shadow board look into my roof Link to comment Share on other sites More sharing options...
DBCooper Posted October 1, 2024 Share Posted October 1, 2024 I think all you need to do is pick a profile for your shadow board and then set the width and height. If you do this in the "build roof" dialog, then it will be set for all new roof planes (but not existing ones unless you have auto rebuild turned on). Also, it may be hard to see them if you have gutters turned on and the shadow board is behind them. Link to comment Share on other sites More sharing options...
decorators3 Posted October 2, 2024 Author Share Posted October 2, 2024 11 hours ago, DBCooper said: I think all you need to do is pick a profile for your shadow board and then set the width and height. If you do this in the "build roof" dialog, then it will be set for all new roof planes (but not existing ones unless you have auto rebuild turned on). Also, it may be hard to see them if you have gutters turned on and the shadow board is behind them. thank you! Link to comment Share on other sites More sharing options...
