JKEdmo Posted September 17, 2024 Share Posted September 17, 2024 Good morning, I have a stair in two separate sections. I want to have the railing on for the lower section, but nothing for the upper. But, it seems to me the railing / handrail setting controls display for the whole (combined) stair. Is it possible to have different railing / handrail settings for the two separate sections? Thanks again, Jim Link to comment Share on other sites More sharing options...
Solution DBCooper Posted September 17, 2024 Solution Share Posted September 17, 2024 Yes. The easy way to do this is to shift-select the stair and then any changes you make will only affect the one you selected and not any of the connected ones. Link to comment Share on other sites More sharing options...
JKEdmo Posted September 17, 2024 Author Share Posted September 17, 2024 29 minutes ago, DBCooper said: The easy way to do this is to shift-select the stair and then any changes you make will only affect the one you selected and not any of the connected ones. Success! I did not know this feature. Thanks! Jim Link to comment Share on other sites More sharing options...
