X16 Porch posts not lining up on both walls
elementsdesign
Go to solution Solved by 3dsDan,
Anyone else experiencing this? I have my offsets for the posts the same on both walls, but the posts will only offset for one wall and not the other. So my column is hanging off the porch 2" on the side...This was not a problem in X15, but now it is in X16.
  • Solution
I think what you need to do is ensure that your post and your rail wall is the same size.  Meaning that your 8-inch column should go into an 8-inch rail wall and the 2-inch difference will go away.
