elementsdesign Posted September 10, 2024 Share Posted September 10, 2024 Anyone else experiencing this? I have my offsets for the posts the same on both walls, but the posts will only offset for one wall and not the other. So my column is hanging off the porch 2" on the side...This was not a problem in X15, but now it is in X16. Link to comment Share on other sites More sharing options...
DBCooper Posted September 10, 2024 Share Posted September 10, 2024 I just tried it and it seems to be working fine for me. You might want to post your plan. Link to comment Share on other sites More sharing options...
Solution 3dsDan Posted September 11, 2024 Solution Share Posted September 11, 2024 2 hours ago, elementsdesign said: Anyone else experiencing this? I have my offsets for the posts the same on both walls, but the posts will only offset for one wall and not the other. So my column is hanging off the porch 2" on the side...This was not a problem in X15, but now it is in X16. I think what you need to do is ensure that your post and your rail wall is the same size. Meaning that your 8-inch column should go into an 8-inch rail wall and the 2-inch difference will go away. Link to comment Share on other sites More sharing options...
