materials slow to load and or open to edit
RL-inc
Good day all,
Real shot in the dark here but I wanted to throw this out and see if anyone else has issues with some, not all, materials associated with some- again not all- objects taking an extremely long time to load in the library browser and plan materials dbx.
Again, it doesn't seem to be related to any one condition or plan in particular - very random.
That said, I was hoping that there may be another user that has run into similar issue and happened upon a cause and solution.
Is the material using a texture (or map) file that is very high resolution?  Is it using a pattern that vey high density or has a lot of lines?
My best guess is that it is something you did with the material.  If you want a better guess, post the plan or an exported library with the materials that are giving you problems.
