JonHayward Posted August 28, 2024 Share Posted August 28, 2024 Sort of a Chief newbie. I have a simple rectangular gable-roofed garage structure with living space on 2nd floor. I have roof build set to ignore 2nd floor (working fine). I am trying to build an external area (calling it a porch currently) but functionally a carport and I want the shed roof to attach to the outside of the exterior wall - below the main roof eave. I cannot figure out how to attach this shed roof to the wall. it wants to build it by joining to current roof with either a single pitch across it all or giving me the option to have separate lower and upper pitch. Is there a way build this simple shed roof and not have it try to join with main structure roof planes? Link to comment Share on other sites More sharing options...
SNestor Posted August 28, 2024 Share Posted August 28, 2024 If you would attach your plan someone would help you. Also...what version of Chief are you using. When you get the chance you should fill out your signature. Link to comment Share on other sites More sharing options...
JonHayward Posted August 28, 2024 Author Share Posted August 28, 2024 Plan file attached. Thanks! X16 M3 Max MacBook Pro 36GB, 1TB SSD Camp Garage Plan.plan Link to comment Share on other sites More sharing options...
Garybills Posted August 28, 2024 Share Posted August 28, 2024 I would draw it manually, turn of auto rebuild and change a couple roof settings. Link to comment Share on other sites More sharing options...
JonHayward Posted August 28, 2024 Author Share Posted August 28, 2024 Awesome - thanks for the help! Link to comment Share on other sites More sharing options...
