Lizettemal84 Posted August 24, 2024 Share Posted August 24, 2024 I upgraded to cheif premier and did not come with plot plan view,where can i get it. I would like to use the defaults on this but mine did not come with it Link to comment Share on other sites More sharing options...
Michael_Gia Posted August 24, 2024 Share Posted August 24, 2024 On 8/24/2024 at 4:49 AM, Lizettemal84 said: I upgraded to cheif premier and did not come with plot plan view,where can i get it. I would like to use the defaults on this but mine did not come with it Expand If you go to the Chief Sample Plans page, most of the plans have a site/plot plan view with all the defaults etc... Just export the defaults from that or even use it as a "Save as Plan" for a template. Just pick one you like. https://www.chiefarchitect.com/products/samples.html 1 Link to comment Share on other sites More sharing options...
DBCooper Posted August 24, 2024 Share Posted August 24, 2024 What did you upgrade from? If you upgraded to premier from one of the other versions, and you are opening a plan that you started in the old version, you probably won't have all of the defaults that come with premier. In this case, you can either import the defaults and settings from the default template that ships with premier or you could start a new plan using the default template and then copy your plan into it (I recommend using edit area). 1 Link to comment Share on other sites More sharing options...
Lizettemal84 Posted August 26, 2024 Author Share Posted August 26, 2024 Thank you guys trying that now I upgraded from home designer pro Link to comment Share on other sites More sharing options...
