rcapone Posted August 12, 2024 Share Posted August 12, 2024 Hi, I am trying to create a parapet wall with the angle. If you look at the pic the roof that has the brown roof. I just want to have the wall portion and where the brown is would be hidden behind it and flat. If you could let me know how to get the roof on the far right to be about 6" below the wall behind I would appreciate as well. Link to comment Share on other sites More sharing options...
glennw Posted August 12, 2024 Share Posted August 12, 2024 Take a cross section/elevation view and edit the wall polyline as needed. Link to comment Share on other sites More sharing options...
Michael_Gia Posted August 12, 2024 Share Posted August 12, 2024 9 hours ago, rcapone said: I am trying to create a parapet wall with the angle. Your life will be easier by creating another floor. You control the height of the walls of that floor with the rough ceiling height in the room definition dialogue box. Then you can make the facade/parapet wall balloon through ceiling above and shape it the way you want. The room height will also control the height of that roof on the far right a lot more precisely than simply raising the roof and messing with walls. You can look up videos on how to create parapet walls. 1 Link to comment Share on other sites More sharing options...
