RobWhite Posted August 9, 2024 Share Posted August 9, 2024 Is there a method of deleting skirting from an individual wall when the default moulding (skirtings) is set for a room? eg. I have applied standard skirting throughout, but I want to remove the skirting from a bar servery in the same room. I am still using X15 and haven't moved to X16. Let me know if X16 has better control for this. Link to comment Share on other sites More sharing options...
DBCooper Posted August 9, 2024 Share Posted August 9, 2024 Yes. Open the wall dialog and look at the options on the general page. Keep in mind that if the wall spans multiple rooms, you will probably need to add a break otherwise it will remove the molding for all rooms the wall makes. If you need more control over your moldings, then click on the room and use the "make room molding polyline" tool. Now you can edit it just like any other molding polyline. Link to comment Share on other sites More sharing options...
RobWhite Posted August 9, 2024 Author Share Posted August 9, 2024 Is that option only available on X16. I don't see anything to remove molding on the general page of the wall dialog. I have sorted this using a poly line but would prefer to know your method Link to comment Share on other sites More sharing options...
edisonmark00 Posted August 9, 2024 Share Posted August 9, 2024 No direct method in X15. You can try manual removal or creating a new wall finish. X16 might offer better control. Link to comment Share on other sites More sharing options...
DBCooper Posted August 9, 2024 Share Posted August 9, 2024 X15 has "no room moldings" in the wall dialog. 1 Link to comment Share on other sites More sharing options...
RobWhite Posted August 9, 2024 Author Share Posted August 9, 2024 Indeed is has...obvious too! Thanks Link to comment Share on other sites More sharing options...
