Larry-H Posted August 6, 2024 Share Posted August 6, 2024 I created the infill to a stair rail with 3D solid objects and want to group them in elevation view how to do - I can use the marquee tool in plan view but how to in elevation view? i am a newbie and 83 years old so be kind Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 7, 2024 Share Posted August 7, 2024 2 hours ago, Larry-H said: I created the infill to a stair rail with 3D solid objects and want to group them in elevation view how to do - I can use the marquee tool in plan view but how to in elevation view? i am a newbie and 83 years old so be kind Can you tell us more, why are you trying to group them, what is your end goal? What was the infill for, there may have been a better method we could point you to. The screenshot doesnt show solids in a stair rail. Consider posting you .plan file for the project. Link to comment Share on other sites More sharing options...
Larry-H Posted August 8, 2024 Author Share Posted August 8, 2024 Thank you for the responce - I used the stair rail posts and rail created from the stair tool and filled in the ballusters with 3d solids (1"x 1" black) and wanted to save the infill as a group to repurpose for the shorter end of stairs rail- It was a lengthy procedure to accomplish using 3D solids- the only way i could see to group these items as a unit was in plan view which for many reasons was impossible in that view- that was why i was interested if a group could be made in section view- then with a combination of plan view and section view I 8-4.plan concept.plancould manipulate the group into place- no doubt there is a simpler way - i am not familiar yet as to the working of all the tools and their locations ): BTW; I did cobble this togethher for a view for subs so it wasnt designed as a complete plan, I somewhat designed this in 3D not sure how to upload file, said it was too large Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 8, 2024 Share Posted August 8, 2024 22 minutes ago, Larry-H said: Thank you for the responce - I used the stair rail posts and rail created from the stair tool and filled in the ballusters with 3d solids (1"x 1" black) and wanted to save the infill as a group to repurpose for the shorter end of stairs rail- It was a lengthy procedure to accomplish using 3D solids- the only way i could see to group these items as a unit was in plan view which for many reasons was impossible in that view- that was why i was interested if a group could be made in section view- then with a combination of plan view and section view I 8-4.plan concept.plancould manipulate the group into place- no doubt there is a simpler way - i am not familiar yet as to the working of all the tools and their locations ): BTW; I did cobble this togethher for a view for subs so it wasnt designed as a complete plan, I somewhat designed this in 3D not sure how to upload file, said it was too large Larry make sure to quote or mension me for faster responses so I get notified. you attached a plan and then deleted the attachment so it is not downloadable. Do you have a photo of what you are trying to accomplish..I have a feeling you are missing a very crucial capability of the railing tools. Can you try posting the plan again? Link to comment Share on other sites More sharing options...
Larry-H Posted August 12, 2024 Author Share Posted August 12, 2024 Renerabbitt I zipped the file but pop up still said it was to big and I sent the wrong PDF originally I attached is the PDF of what I was trying to accomplish Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 12, 2024 Share Posted August 12, 2024 4 hours ago, Larry-H said: Renerabbitt I zipped the file but pop up still said it was to big and I sent the wrong PDF originally I attached is the PDF of what I was trying to accomplish Select your solids and in your edit toolbar use the convert selected to symbol tool and convert to the symbol class millwork. Then change your railing style to panels and apply your new millwork as the panel Link to comment Share on other sites More sharing options...
DBCooper Posted August 12, 2024 Share Posted August 12, 2024 This sounds familiar. Link to comment Share on other sites More sharing options...
