Looking for a thin AC CU for a pool bath?
ACADuser
I have a situation where the client wants a small AC unit for the Cabana toilet room.
The issue is the Cabana is very close to the property line. Anything within 3 feet of the property line needs to be one hour fire rated.
And they don;t allow equipment in the 3 feet.
The side is set back to 3'-6" & I could push it a bit more. Maybe to 4', so I need a very shallow condensing unit.
They don't want it on the roof because you can see it from the 3rd floor.
It can't be on the South side ether.
My bad.  I didn't catch the outside unit.  Given the room size, and balancing this with cost (a window unit is only $200), what if you inset the wall between the doors, reducing just the toilet space to 3'4", leaving the bathroom 4' wide at the sink?
image.thumb.png.ece7d3840ec97a11cfcc8f554a2c78fe.png image.thumb.png.f7a4cb305f084db280d11b89445ec9b3.png
I also reduced the doors to 2'6" wide and made the bathroom 7'8" deep.  I am showing the inset wall as block, but it could easily be a 6" siding wall, accenting the block to either side and increase the toilet space to 3'6".  This allows a passthrough that is a few inches wider than a 5,000 btu unit to maintain airflow on the outside.  These small ac units are only 15"-16" deep.
