Window / Door Schedule - Shutters Yes / No
JKEdmo
Go to solution Solved by DBCooper,
  • Solution
No, but there is a built-in column for "shutter type" and another one for "shutter sides" that may be close enough to what you need.
Since "shutter type" will report the name of the library symbol, you could create a symbol for your shutter called "Yes".  You might even be able to create another library symbol called "No" that doesn't have any 3D if you really need to show both the yes/no in the schedule.
Other than that, you could probably do it using a custom column and macro.
