JKEdmo Posted June 25, 2024 Share Posted June 25, 2024 I created a simple pony wall symbol out of solids with a stretch plane to lengthen the wall. However, when I stretch it the stone wall material does too. How can I keep the stone material from distorting? Thanks again, Jim Link to comment Share on other sites More sharing options...
Solution MarkMc Posted June 25, 2024 Solution Share Posted June 25, 2024 Select the material -copy and rename or just adjust material- check global symbol mapping Link to comment Share on other sites More sharing options...
JKEdmo Posted June 25, 2024 Author Share Posted June 25, 2024 1 hour ago, MarkMc said: Select the material -copy and rename or just adjust material- check global symbol mapping Mark - Thanks much! Jim Link to comment Share on other sites More sharing options...
