Steve_Nyhof Posted June 23, 2024 Share Posted June 23, 2024 You can find these HDRi backgrounds on the web for free, so I put them together into a X16 Library. 500 Mb File... https://drive.google.com/file/d/1Z1TXAw3rGEmUVDoaQRbxZ93hxoDGFc0Y/view?usp=sharing These are 4K. The last backgrounds I uploaded some time ago were 8k which are too large for most computer setups. 6 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 23, 2024 Share Posted June 23, 2024 Hi Steven, Is there a way to set HDRi backgrounds to be at a size relative to the Chief model? Is there a way of positioning the model at the center of the background? My model is pretty close to the [0,0] origin but I don't see any way of coordinating the HDRi background to the model scale and center. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted June 24, 2024 Author Share Posted June 24, 2024 Hi Joe, 19 hours ago, Joe_Carrick said: Is there a way to set HDRi backgrounds to be at a size relative to the Chief model? Is there a way of positioning the model at the center of the background? You can control the size of the backdrop by increasing the Horizontal Tile to 2 - I have done this a few times to push the background away from the model a bit. You may also need to control the Vertical Max and Min to bring it back into the right perspective. The only thing I think will work is to move the whole model to more of the center of the default paper size location (I use "D" size). I have not tested if changing the paper size would make a difference - seems like it would. hmmm Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted June 24, 2024 Author Share Posted June 24, 2024 Changing the paper size does not change the image size Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted June 24, 2024 Author Share Posted June 24, 2024 Changing the Resolution to something higher makes no difference. Chief must have a set diameter that it is setting the image size. Right now you can change the Horizontal Tile to 2, to push it away. You can use Photoshop, Camera Raw Filter... to mess with the greens and blues and other settings. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted June 24, 2024 Author Share Posted June 24, 2024 Photoshop also has a specific DBX to modify HDR images... Link to comment Share on other sites More sharing options...
ericepv Posted June 25, 2024 Share Posted June 25, 2024 Thanks Steven! 1 Link to comment Share on other sites More sharing options...
Chief_Trent Posted June 25, 2024 Share Posted June 25, 2024 On 6/23/2024 at 2:31 PM, Joe_Carrick said: Hi Steven, Is there a way to set HDRi backgrounds to be at a size relative to the Chief model? Is there a way of positioning the model at the center of the background? My model is pretty close to the [0,0] origin but I don't see any way of coordinating the HDRi background to the model scale and center. Hi Joe, The way we render backdrops in Chief is tied to the positioning of the camera and not related to the location of the model in the plan. Having your model near the origin or really far away won't impact how the backdrop looks behind it. Moving around the camera relative to the model will change the centering of the backdrop and zooming the camera in or out will change the scale of the backdrop in relation to the model. One tool which is helpful for positioning the background in your plan is the "Rotate Spherical Backdrop" tool, which can be found in the same tool palette as the "Cross Section Slider" (see attached image). This tool allows you to drag across the screen and adjust the horizontal rotation of your backdrop to get it to line up as desired. In terms of changing the perspective of the backdrop and maintaining an image that looks accurate, we don't have a way to do that in Chief as the perspective of a spherical backdrop is a result of the original image it comes from and where the camera was positioned within the environment when it took the picture(s) used for the backdrop. Yes, you can change the horizontal tile size to 2 to make the backdrop appear further away, as Steven mentioned, but doing so results in mapping a spherical image onto a hemisphere so it won't look completely correct. 1 Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted June 26, 2024 Author Share Posted June 26, 2024 Thank you! I love the rotator tool. It does not have an end like within the DBX - thank you for sharing 1 Link to comment Share on other sites More sharing options...
robcon7 Posted July 23, 2024 Share Posted July 23, 2024 Thanks Steven, Very nice backgrounds! Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted July 23, 2024 Author Share Posted July 23, 2024 You're welcome! 1 Link to comment Share on other sites More sharing options...
NRST8TRKR Posted October 23, 2024 Share Posted October 23, 2024 Steve, Wow, Great job! Thanks again, Ken 1 Link to comment Share on other sites More sharing options...
SteveHRD Posted February 7 Share Posted February 7 Just downloaded these backdrops. Thanks so much for taking the time to share them Steve, they're great. Much appreciated! 1 Link to comment Share on other sites More sharing options...
