KristjanM Posted June 10, 2024 Share Posted June 10, 2024 I have a rectangle with a label - macro values for perimeter and area plus two macros for perimeter and area using number formatter. All values display correctly. In a text box, I place exactly the same text as in the label. The two built in macros for perimeter and area display but the number format macros don't work. Can this actually work? Different syntax in the text box? Link to comment Share on other sites More sharing options...
Renerabbitt Posted June 10, 2024 Share Posted June 10, 2024 4 minutes ago, KristjanM said: I have a rectangle with a label - macro values for perimeter and area plus two macros for perimeter and area using number formatter. All values display correctly. In a text box, I place exactly the same text as in the label. The two built in macros for perimeter and area display but the number format macros don't work. Can this actually work? Different syntax in the text box? youd have to script in logic for owner vs referenced or simply make a new macro that is referenced, or put in %referenced.area% Link to comment Share on other sites More sharing options...
KristjanM Posted June 10, 2024 Author Share Posted June 10, 2024 Okay, interesting. If I put refenced into the number format macro, it now works in the text box. However, now it doesn't work in the label. Seems like two macros are required for the different uses. Thanks for the help. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 11, 2024 Share Posted June 11, 2024 So at the beginning of the macros add this: referenced ? obj=referenced : obj=owner then add obj. in front of each of the lines that are displaying the data That will make the macros work for whichever way they are being used. You might want to look at my template in https://chieftalk.chiefarchitect.com/topic/39977-macro-coding-template/ Link to comment Share on other sites More sharing options...
KristjanM Posted June 11, 2024 Author Share Posted June 11, 2024 Joe, I will try your directions out. Your template will be my homework. Thanks. Link to comment Share on other sites More sharing options...
